Rowandish
CLI missing Set .NET Framework to version, Pin to Taskbar options, Don't save system restore points
Hi all,
I could not find how to perform these operations using the CLI:
* Shortcut Properties - Pin to Taskbar - Automatically Pinned
* Launch Condition - Software - Set .NET Framework to version
* Install Parameters - Minimize installation time - Don't save system restore points for installation
Am I missing something?
If it is not possibile, I think it could be a good feature to improve the CLI to automate che aip creation.
Re: CLI missing Set .NET Framework to version, Pin to Taskbar options, Don't save system restore points
Hi and welcome to our forums.
Indeed, I'm afraid that command line options does not exist for the operations you mentioned. We'll consider your suggestion for adding these options, but I cannot say how soon they will be available. Thank you for your suggestion.
This improvement has been added in version 21.2 of Advanced Installer.
Return to “Feature Requests”
